Lbizzle
You can tell it’s bent bad in the back but I’m not sure how bad the front. I’m just gonna bend it back. But I need pictures of a straight one to see as a reference. It’s a outcast 6s. I appreciate the help!
The kick up affects the front end overall castor angle. A Rear wheel drive chassis usually has more Front end "kick up" than 4WD. This helps rear drive rigs to reduce inherent understeer. IMO. And there are many other factors to this equation.The front kick up is normal without that bend in the front you steering will be completly garbage thats why when you go backwards your steering goes funny
Idk what the name if of that kick up but even irl cars have that in the chassi or it will be almost impossible to go streight
Spend the $10 or so and just get a new one. That one looks beat to hell and back.
https://jennysrc.com/collections/ar...wb-senton-typhon-ar106021?variant=33153803014
Nah all stock there. I guess it’s time for some. Who makes the best one?Myeah the rear is bended thats not normal do you have any metal braces suporting your chassi?
Rear is savagely bended oof
I thought only the K8S bends their chassis? ???
Wait, It’s only 10 dollars for a new chassis?Spend the $10 or so and just get a new one. That one looks beat to hell and back.
