- Mississauga
- 4x4-Mega
- BigRock 4x4
- Granite
- Typhon 3s
Er. . . Jim's?Should be no play.. Jim's sells sets for that can.. ?
Kk but I would just jam the 4070 or whatever in and use the blx 100 esc and pus 3S through it. Is that working or stupid?you can try ? but i would just buy a 6s.
because that plastic cannot stand that and you have to reinforce everything internally.
That costs a lot and you better put that money in a 6s ?
I once made a 4s out of a 3s ? and a waste of your money
Bearing probably came apart in motor an locked rotor up,an bent motor mount.is shaft LOCKED UP? If so motor is trash. All stocked 3s Motors I've owned bearings went out and overheating just go to a big block.3674 or 40 series. Just make sure u go with motor above 2000kv'sThere shouldn't be any play in the motor shaft should there be? There is a slight movement laterally now.
Is there a replacement front bearing for this motor?
Blx100 esc& 6s motor works good together.ive tried LOTS OF DIFFERENT COMBOS.must use 26t to get the speed.there are cheaper motors you can use but shipping takes long time.surpluss 4076&4068&3674 are great motors.once I burnt up my stock motors went to 40 series motors an will never go back,its the way to go
If stock 3s motor is fixable these are bearings you need.im in st.louis mo,I got some I'd give you,if you want to come pick um up.....LOL
I found stainless steel ones from Canada bearings in Woodbridge ontario.If st
WORD OF ADVICE. if you run stock 3s motors replace bearing with better sealed ones before they go out.THEY WILL. Those Motors are great Motors and they're very fast but they overheat an the bearings go out. I put a big block in through the summer times and then when it cools down those 3 s engines would be great for cooler under 60 degrees bashing
