Got a arrma felony and when inspecting the drive train by rotating the center diff by hand with no motor installed I am noticing a lot of run out on rear drive shaft. It appears to be bent more then I would like to see. Any body experience this with felony or other on road 1/7. Probably have to remove to see before 1st run even. New car.is this common? One side of shaft hits suport bearings an other doesn't makes me think shaft bent from factory.
