Get a 4mm tap and bit for the tap, then drill it out, retap for 4mm, then use a 4mm bit to drill out the top plate and use a 4mm bolt.My front hot racing brace, top screw keeps on bending! Any tips to fixing this thanks!
Thanks much buddy! Wanting to make it a tank!Get a 4mm tap and bit for the tap, then drill it out, retap for 4mm, then use a 4mm bit to drill out the top plate and use a 4mm bolt.
M2C did that on their front brace. They include a bit to drill out the top plate to use it.
That's what I did. And have an m2c chassis??Get a 4mm tap and bit for the tap, then drill it out, retap for 4mm, then use a 4mm bit to drill out the top plate and use a 4mm bolt.
Correct response! If it breaks again get the m2c brace and make sure it's set at 4 mm?That's what I did. And have an m2c chassis??
