Terrance
Do these shock towers look bent to anyone else??
Ya i figured man thanks. Does that front one look good to you?
Thanks man!It's hammer time!
Take them off and they straighten easy enough with a hammer. you can be graceful and place between two pieces of wood.
I would do the rear first and make as good as the front. If that turns out better than the front then I would try the front.
Front does look close to good enough from a pic, but I would put a straight edge behind it and check for yourself. Rear for sure is a dogs hind leg ?Ya i figured man thanks. Does that front one look good to you?
Thanks man!
