Yes, SCT. The kv matches with the stock vorteks motor. But, on this website it says that the motor is 2-3s.But did you look at the Max10 SCT version ??
This one IS 4s.
Choosing the Correct Kv motor for your Vorteks, is paramount however!!
I know, I saw that also. That is why I said that you have to carefully pick the right Kv motor. Dropping down in KV over stock might be better?Yes, SCT. The kv matches with the stock vorteks motor. But, on this website it says that the motor is 2-3s.
Now that I've thought about it, I might not switch. Should I just buy myself another stock motor? The other one that I have is completely fried.I know, I saw that also. That is why I said that you have to carefully pick the right Kv motor. Dropping down in KV over stock might be better?
Because you are upping the volts. Why are you going 4s anyway?
3s seems to be the sweet spot for the Vorteks and most 4x4's. Drivetrain reasons.
