Senton Best diff fluid combo for speed runs.
Bashbros
Ventura
Senton,
I just bought a roller from a friend and planning to run 100 + mph on it. I also bought a tp power 2700 kv and a castle XLX esc. What is the best diff fluid combo to use? Front, Center, Rear combination.
Yonic
Tel Aviv, Israel
Senton, Talion, Typhon 6s, Typhon 3s, Voltage
as higher as you can get, even lockers if you have, esp in the middle.
joostin420
MA/NH
Fazon, Kraton 6s, Outcast 6s, Senton, Typhon 6s
Interested in the recommended diff fluid also.
bicketybam
RC Grand Champion
New Milford, CT
BigRock 4x4, Granite, Infraction, Kraton 8S, Kraton 6s, Kraton 4s, Mojave, Notorious, Talion, Typhon 6s
Don’t people just run a spool for high speed applications? Totally locks the wheels and you can run a big pinion.
joostin420
MA/NH
I don’t want to run spools though since I want to run on a little more than just tarmac.
Spar69!
Virginia
Kraton 6s, Notorious, Talion
I run 60k/1M/60k in my Talion with a 25T pinion and got 81mph and to me it's the perfect weight for speed, I'm able to keep the front end on the ground and haul a$$....And performs beautifully off road as well.
joostin420
MA/NH
Those numbers may be my route then ;)
Spar69!
Virginia
Good stuff! The Million weight is ALMOST like a locker you literally have to dig it out with a screwdriver but it also has just enough give to not tear up your center diff on Big Air landings...
Create account
Log in
