calebgilmore
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Mojave
- Notorious
- Outcast 6s
- Senton 6s
- Talion
- Typhon 6s
- Vorteks
- Voltage
Most of the recommendations for a 1650 seem to fall closer to 20-22t for the pinion. Depending on cooling you may want to start there and bump it upI finally picked up a Talion and put a castle setup in it running MMX8S w/ 1650kv motor. It has 50t/30t but it gets a little hot after 30 minutes of street bashing. I'm still trying to figure out the gearing to go with. I'm not sure if I want to keep the center LSD diff or put a 39 spool in it. I can run it on 4S or 6S. The 6S setup is better balanced.
What do you guys think would be a good gear setup to run and why?
