- Kraton 8S
- Kraton EXB
- Mojave
- Outcast 8s
- Outcast EXB
- Typhon 6s
Hey man, thanks to your post I got a 12x12, 1/8” thick square of that material to experiment with. So how did you work it? What is the best way to cut it into shape, do you heat it up before you cut it or use a Dremel or a bandsaw cold? I’m not sure where to start having never done something like this but you are right, I’m crafty and can figure it out...once I know where to start
Thanks bud!
I think I used 1/4, 1/8 should bend pretty nice. I basically made a mock up out of cardboard and drew lines where I wanted my bends. Then I transferred it to the hdpe and used a 2x or whatever scrap wood I had that worked best. Slowly heat it up from both sides. Once it is bent and starting to cool down I’d run over to the sink and run it under cold water to speed up the process.
I used a heat gun to heat it up, working back and forth not heating one area too long. To cut it I just used my jigsaw.
