I installed the Hobbywing Max8 yesterday, turned the BEC up to 7.4v and went for a test.Much better than the stock version, no lag, quicker acceleration!! Good upgrade!yeah I've heard a lot about castle though. everyone talks about them.
hey.. i bought the mamba 2028 for my kraton v2.. any suggestions on pinion size or set up?Castle Creations makes great motors and ESC's.
I have the first setup you mention and it does run cool,but i would get the Leopard 4282 instead( has sealed can and cooling fins).I have the same question and thinking of two options for my kraton 2015 that i just bought;
1: Hobbywing max8 + Leopard 4082 2000 Kv
2: Mamba Monster V2 ESC + 2200 KV motor
3; Just replace the stock esc for with the hobbywing max8
Currently im running 4s but i guess 6s will get in the Kraton soon.
Its mostly bashing and less speed runs what i do.
My goal isn't higher topspeed but lower temps and therefor longer runtime.
What are the pro's and cons for the options mentioned and what would you go fore?
Thanx for your input!
Thanx Kauaiguy,I have the first setup you mention and it does run cool,but i would get the Leopard 4282 instead( has sealed can and cooling fins).
13t Robinsonracing pinion and stock spur.If your looking for a big increase in power,than go with the 4292( it is heavy).The Leopard use 3mm screws instead of the stock 4mm,with the 4082 i haven't had my spur slip,but with the torque of the 4292 1730kv others have and had to retap the mount holes to 4mm.Thanx Kauaiguy,
What pinion/spurgear are you running whit that setup?
With the Leopard 4282 mayby i don't need the aluminium case and fan you have installed?View attachment 3617
Thats the reason for the 4282 version, but i haven't tryed it myself.With the Leopard 4282 mayby i don't need the aluminium case and fan you have installed?
Hey Fox.. My Leopard 4082 1600kv just arrived. Waiting on Mamba Monster X ESC. I'll keep u posted. That L 2000kv is a beast I heard.I have the same question and thinking of two options for my kraton 2015 that i just bought;
Thanx Dubbel-A,I started with a Hobbywing ESC and a Leo 4082 2000kv. Then I put that motor in my Senton and got a Leo 4092 1730kv for the Kraton.
Can't go wrong with either motor but the 4092 is better for the heavier Kraton. The 1600kv is probably even better!
Sorry for asking all this, im new in the rc hobbyWell, its more like which motor is better suited for the application.
In a heavier car, the 1600kv can run safer on 6s, can be geared up, and generate less heat than the 2000kv motor so that's why most would say 6S/1600. But, geared correctly, you can easily get away with running the 2000kv on 6s. That's what I did for a while and it ripped. I just had to monitor temps at it ran hot towards the end of a run.
