Best scissors to cut lexan
DoubLRRLIFE!8887
  1. Infraction
  2. Limitless
  3. Kraton EXB
  4. Typhon 6s
First body I’m cutting/painting so lots of questions .
I see people here have a preference when it comes to cutting them up, let’s hear it and those are the ones I’m getting thanks fellas.
DoubLRRLIFE!8887
  1. Infraction
  2. Limitless
  3. Kraton EXB
  4. Typhon 6s
The word on the street is the Tamiya scissors are the best.
These?
I found the Team Corally ones really good personally.
Do you have link?
KevinC
Flyboy, Cat Hoarder, Booze Junkie, Snail Wrangler
Brantford,Ontario
  1. Fireteam
  2. Kraton 8S
  3. Kraton 6s
  4. Kraton EXB
  5. Mojave EXB
  6. Talion
  7. Talion EXB
Cutting a lexan body can be tricky. The above scissors are the best.
This guy here demonstrates how to do it properly……do NOT use scissors to cut curvy parts. Score with xacto first, then follow through. You will get great results.
Diem Turner
Yes...I have a Premium Member
Rig of the Month Winner
Wienerslider, Germany
  1. Infraction
  2. Kraton EXB
Tin snips or, my personal preference, a scalpel and the score and snap method. I've used this on Lexan thickness up to 2mm. Here's a demonstration of how it works. Done correctly, it produces the best edge by far that requires the least amount of sanding and touching up. Once you do it this way for the first time, you'll never go back to scissors again.
LicketySplit
Space Shuttle Door Gunner
Miami, FL
  1. Limitless
  2. Outcast 6s
I tried that but with the delta bodies the knife just wanted to run away.
Diem Turner
  1. Infraction
  2. Kraton EXB
Might be down to the knife you're using. The commonly found scalpel or Exacto blades are too long and thin and tend to be a bit too flexible which allows the blade to deflect too easily. I've been having success (even on the 2mm Delta bodies) with Bittydesign's knife which has a short and stiff blade. It definitely gives you better control over where the tip of the blade is.
LicketySplit
Miami, FL
  1. Limitless
  2. Outcast 6s
Interesting. I just might have to give that a shot. Makes sense. I remember trying it and thinking I wish I could grip it closer to the tip like a pencil. Thanks bro!
Fishtank
work the hardest when no one is watching
Arizona
  1. Infraction
  2. Kraton EXB
You know I’m going to destroy it right? 😂 chew the edges off and let’s drive it!!
Ajag
  1. BigRock 4x4
  2. Felony
  3. Infraction
  4. Limitless
  5. Kraton 8S
  6. Kraton 6s
  7. Notorious
  8. Outcast 8s
  9. Outcast 6s
  10. Outcast 4s
  11. Talion
  12. Typhon 6s
Personally I prefer these bitty designs scissors
https://www.amainhobbies.com/bittydesign-curved-polycarbonate-scissors-bdyss-37855-c/p968655
But the tamiya work pretty good as well
I use the curved scissors to cut all the curved areas such as wheel wells etc and use a pair of big scissors (good quality ones) like these for all the long straight cuts
https://www.amazon.com/Fiskars-1541...words=titanium+scissors&qid=1675515818&sr=8-9
Then I use 120 grit a sandpaper to sand all the edges ..scuff the inside with red scotchbrite ..clean the inside with isopropyl alcohol and that’s it
Good luck 👍🏼
