Yeah, I have got Savox too.Savox 1212
Cheap 35kg amazon/eBay servo
Finally someone on here who knows a good servo. Hard to believe most people run savox when they don't offer much of a speed upgrade over stock .16 speed on 6v. Both these servos definitely are much faster, stronger, and more durable. Excellent choices.Reefs Rc tripple 4
or protek 370tbl
View attachment 89816View attachment 89817
That’s a beast of a servo too!!Savox SB-2290SG Black Edition Monster Torque Brushless Steel Gear Servo
Specifications:
Torque: 6V: 555.5 oz-in; 7.4V: 694.4 oz-in
Speed: 6V: 0.16/60° sec; 7.4V: 0.13/60° sec
Dimensions (L x W x H): 40.3x20.2x38.7mm
Weight: 79.0g
I went that route w my senton 6s until steering failure caused high speed wreck. Since then I’m a sucker for the high priced servos. Loli use a cheap 30$ amazon 35kg servo. Works mint. It wont give you 35kg at 6v.... but it will give you over 30. so plenty.
Understandable. I have had excellent luck with the cheap servos.I went that route w my senton 6s until steering failure caused high speed wreck. Since then I’m a sucker for the high priced servos. Lol
Yeah, you tight about Savox, they crap, mine month old just died.. Have ordered JX ecoboost.Finally someone on here who knows a good servo. Hard to believe most people run savox when they don't offer much of a speed upgrade over stock .16 speed on 6v. Both these servos definitely are much faster, stronger, and more durable. Excellent choices.
Very good point!Servos are all a mixed bag. Cheapos or High $$. Just accept that what you have will break. I tried it both ways. Cheap and High$. I lean to cheapos as of late. Its more cost efficient as you keep replacing them over the years. I don't see any better longevity or worse based on the $$$ you pay. Precision may be better on the high end side. But not always when it comes to servos!!!
I would consider a Promodeler Brand servo next in the high end side of servos. Gave up on Savox for good. Most servos are just re branded generic Mfr'ed. Most of the servo components are also. The servo's Potentiometers is what truly separates the $men$ from the boys.
Edit: make sure the servo can provide at least 25-35 KG at 6volts and it should serve well enough for bashing.
