- Location
- SE PA
- Kraton 8S
- Kraton 6s
- Mojave EXB
- Outcast 6s
- Talion
- Typhon 6s
M2C mount works with 49mm motor cans as well.
Thanks. Sounds scary now lol. My diff shft cup thingys look a bit warped where the dogbone go into and the pins in the dogbones are like worn too so a motor thats way stronger seems scary.Ok, my 2 cents, I run Max6 with TP 4070 1520kv, Y motor, 23/50 , 500k in cent.diff. Max6 is way more capable then numbers states.
I use 6S Graphene Panther 5.000 mAh 75C battery(it requires battery tray modification) and can tell:
It will eat battery in a few minutes, and Max6 will be around 100C .
Push it hard, it will brake things, I mean hard steel things.
Be careful with high grip wheels (Backflips and similar).
It will tear tires like crazy.
It will give you a hell of a fun!!!
This picture below has it's story: First it broke diff pins(changed to drill bits), then it broke diff sun gear, then it broke dog bone end and finely when all was tight enough it just cut the diff end cup in half, not wear it down, it cuts it clean, so you can perfectly put it together.
Ill prob look into that motor.I got a TP 4060 1950kv initially for use in my V3 Kraton with a Max6, the TP rep recommended it for my application when I was first looking at motors. It's been a solid performer...
