Hector_Fisher
I've got a couple of projects in mind that require ESC upgrades, for 4s and 6s. Normally I'd be looking at the max10 sct and max8, but the max8 is now discontinued in favor of the more expensive and sensored max8 G2 ESC, and the max10 sct is looking to be going the same direction with a G2 as well. Wanting to get some feedback and thoughts or other options you have seen. Are there other/better options you'd consider? Disagreements with my assessments? Other ways to shave down costs? I'll try to return and add suggestions that other members contribute!
4s:
Max10 SCT - very good option for bashing. Robust and reliable. Still some "non-G2" stock around and some from kit breakers ($80ish) might be discontinued soon?
Max10 SCT G2 - expensive, but sensored if you have a sensored motor to match. New to community. Robustness still in question?
Spektrum 130a - expensive as OEM ($130ish), but decent value from kit breakers like Jennys (around $85ish shipped), overall fairly robust for bashing and good programming options.
6s:
Spektrum 150a - good programming options, easy to come by, relatively inexpensive at kit breakers (around $90ish shipped), but does have a poor community history of going up in flames on random occasions. Probably best if used in stock power or lighter duty applications.
Torox 185a - good programming options, but only available from kit breakers? Slightly more expensive (around $100ish shipped). Robust and good community history.
Max8 - limited supplies available, if you can find it. Perhaps try aliexpress RTR options?
Max8 G2 - expensive, potentially some teething issues with reliability on the first batches so far.
4s:
6s:
