Kraton BicketyBam's V3 Kraton
bicketybam
Back from vacation!
New Milford, CT
  1. BigRock 4x4
  2. Granite
  3. Infraction
  4. Kraton 8S
  5. Kraton 6s
  6. Kraton 4s
  7. Mojave
  8. Notorious
  9. Talion
  10. Typhon 6s
I just got done installing all the Voltage Hobbies braces along with the M2C chassis. At some point I will list all my upgrades and post finished pictures with tires and the new body. I tell you this. I wish I never installed a T2T because they marred up my beautiful VH shock towers.
That’s a clean nice looking build. Do thoes front dirt guards come stock on the Kraton or is it a aftermarket pice.
Well here is the damage. I think I got everything:
Voltage HobbiesFront/Rear Shock Towers (Blue) $76.96
Voltage HobbiesServo Mount $23.98
Voltage HobbiesServo Clamps $9.98
Voltage HobbiesSteering Rack $16.98
Voltage HobbiesRear Chassis Brace/Wing Mount $22.98
Voltage HobbiesUpper Arm Mount $19.98
Voltage HobbiesFF Lower Suspension Mount $18.98
Voltage HobbiesFR Lower Suspension Mount $24.98
Voltage HobbiesRF Lower Suspension Mount $20.98
Voltage HobbiesRR Lower Suspension Mount $21.98
Voltage HobbiesRear Skid $9.99
Hot RacingAluminum Center Differential Mount $18.88
Hot RacingAluminum Center Diff Brace Gear Cover $18.88
Hot RacingAluminum Steering Blocks $49.88
Hot RacingAluminum Rear Hubs $46.88
Hot RacingChannel Lock Secure Motor Mount $38.88
Hot RacingAluminum Front Chassis Brace $23.88
Hot RacingAluminum Rear Chassis Brace $23.88
SavoxSW-1210SG $81
M2C RacingGoliath 4mm Chassis $110
Proline Trenchers - Pre Mount $100
RPM Front A-Arms $26
RPM Rear A-Arms $14
RPM Front Bumper/Skid $18
Total: $837.88
Kind of sobering when you add it all up. I added a lot of this stuff for the bling factor. By no means do I feel it needs all this. I do want to upgrade the electronics though. The truck weighs a ton.
EDIT: Forgot the RPM stuff. Added that in.
^^just bought a set of those tires for my Kraton. Do you like them? Lhs had them and I thought they felt good but I do wish the were offset a bit.
what's the weight difference between yours and the out of the box Kraton? For reference, my unmodded Kraton is 4440g (no batteries or shell, some mud included)
They balloon badly so I wrapped them with fishing braid. As far as in the dirt perforamnce, they are awesome. And they don't tear up my lawn like the Backflips on my Notorious.
I feel stupid admitting this but I just realized today that are vented through the tire and not the rim.
Holy shnykees man that is a tank! Nice build! How does the stock springs feel with all of the new aluminum?
I haven't run it yet. The true test will be when I take it to the BMX track.
I don't have any way of weighing it. I'd love to know though.
Amazing work Bick. My only suggestion, you should by a clear body and custom paint it, leaving a few key areas clear, to show off the bling. It is so well done, feel like it deserves a custom tailored suit to cover it. ??
