Big Bore aluminum shocks
dan207265_RC
I just order high performance big bore aluminum shocks from eBay for my vorteks 3s and my son typhon 3s what weight oil should I use I was looking on YouTube and there using 35W…thanx
I thought I saw a few people using 60wt.
Do they have eBay Big Bore shocks for the Arrma Vorteks yet? The ones that are for the Granite/Senton/Typhon/Big Rock Crew Cab are too long for the Vorteks.
Have a read through here https://www.arrmaforum.com/threads/...rock-crew-cab-and-vortex-shock-upgrade.42570/
Yeah they do have them I order some…I’m gonna try them out…
I just saw that.
Idk if they have changed those shocks since I bought mine, but there are no bladders and there in no bleeder hole in the caps so bleeding them was a bit different, my springs were way too stiff, the balls didn't move freely in the rod ends, the rod ends were rather weak, I ended up using Traxxas rod ends iirc, they leaked and both of the rear shafts bent.
I have seen some people who haven't had any issues with them and some who have so maybe qc is a bit lacking on them.
And before I forget you will need Axial shock bushings part number AXA1356 https://www.amainhobbies.com/axial-...rnbHUM_wNZFy8MaTB2F-nky5JES85lvRoCl3QQAvD_BwE for the top mount of the shocks.
I just saw that.
Thank you on getting those shock bushing they fit good and no slack on the shocks...thanks alot..
