So my arrma big rock has got a problem.
The left wheel of it cambers itself (see pic) as soon as i take a turn. I can move it straight by hand but then aftrr turning it happens again.
Anyone know what the problem is?
It isn't i just checked
HereDid you lose or shatter an inner bearing on the steering block? That picture is so low res that it’s hard to tell. Can you take the wheel off and post some better pics?
This or the steering hub carrier. My bets on the hub carrier.
My question is when you pull the tire back straight, what is moving? Because that will be your problem.
Yup, that’s the steering hub carrier I mentioned earlier. Those are the part I break most so have a bunch of spares. The rears also I keep extra as they wear out quick and break more than other parts. I stock up on the hub/c block sets on Jenny’s.Bottom of the hub is snapped out of it, where the pivot screw goes through.. common breakage...
I like this guy!.. he speaks the truth...
Zelle.So @slick2500 - PayPal or Venmo?
