Thanks! I'll get this.https://www.ebay.com/itm/Arrma-BIG-...on-AR102711-/392182175604?hash=item5b4fe11774
I would recommend getting a set. arrma uses good screws,12.9 grade
Tonys screws? Never heard of them. Link?
I'm almost willing to bet the issue is more the tools you are using than the screws themself. What hex wrenches are you using?Does anyone know of a stainless steel screw kit for the big rock c.c 3s? The stock screw hex heads seem to strip easily. Thanks!
Im using a dynimte hex kit that comes in a black pouch. I agree, they're not the best.I'm almost willing to bet the issue is more the tools you are using than the screws themself. What hex wrenches are you using?
I know stainless steel is pretty but I'd also suggest going with black oxide screws over stainless steel as black oxide screws are typically MUCH stronger than stainless steel.
