Is your motor mount bent? How about your motor bearings?I've been through two spur gears in about 3 months. Are there any downsides to upgrading to a metal spur?
Or maybe landing while on the throttle?Is your motor mount bent? How about your motor bearings?
The damage to the pinion has nothing to do with the spur being metal. I chewed up two 15t pinions with the plastic spur due to the dirt and sand before I cut the slit in the chassis. I've ran like I said last 8+ months with metal spur and slit, both pinion and spur have almost no wear at all. My guess for your case is too tight or loose of gear mesh, bent motor mount, bad bearing or more so debris inside acting as sand paper.I found the metal spur just ended up chewing up my pinion. It could have been due to a bent motor mount, but I went back to plastic. Other downsides of metal are heavier weight and more noise. I've taken steps to keep dirt out of the power module and upgraded the motor mount. With these steps, the plastic has been holding up.
Get the HR motor mount.Thanks all. To answer an earlier question, my motor mount is bent. It's my second motor mount which needs replacing. I slammed into a curb, which is probably when it happened.
It sounds like I might be best off just sticking to plastic again for now. With this hobby I need to get in the habit of buying two of everything.
