I believe the Proline jeep Gladiator fits. The Carisma ford f150 also fits but not really a bashing body as you need to remove the front bumper.Looking to get a new body for my big rock. What bodies fit the best. don't wanna buy something that doesn't fit
I can't find the bodyshell width anywhere for the notorious but the truck itself is wider than the big rock so I think it would be too big (although the wheelbase is fine). The standard big rock shell is about 170ish mm. Anything over about 185/190mm and the wheels will rub.does a notorious 6s body fit the arrma big rock?
looks like the length should be fine but what about the with?
I need this in my life. Who makes?I believe the Proline jeep Gladiator fits. The Carisma ford f150 also fits but not really a bashing body as you need to remove the front bumper.
Anything around a wheelbase of 320-330mm and no wider than about 185-190mm max should work. Obviously you need to consider position of body mounts.
Not 100 percent sure but I have seen people switch over .the chassis is the same length on both but the v3 has lwb .Is the v2 blue body an exact fit for the v3?
