bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
I had to try it ? I put the Castle Mamba X and the 1512-2650Kv motor from my original Granite into the Big Rock CC. I went with a 20t pinion for 2 reasons. 1. It gives me about the same top speed as the stock setup (it's a few mph faster with the Castle) and 2. There is a pre-drilled hole for 20t in the mount. I also went and cranked the slipper down. It was about 2.5 turns out from full tight. I set it at half a turn out from full tight. I ran the Granite tires and set the Castle punch to halfway (50%). Truck is so smooth from the start due to to sensored motor and it has gobs of torque. I ran a full battery through it and wheelies are not a problem! I am definitely pleased with this setup. At some point I will hit the ramp and see how she flies ?
