chevyrumble
Update #1: LED Kit
I have only been a member of the forum here for a little while, but figured I would start this thread since I am working on a custom painted body, LED package, and a few other modifications to my Big Rock. A while back now I started fallowing a few different YouTube channels that focus on the RC Hobby. Not long after I purchased my Arrma Nero Big Rock and pretty much immediately decided that I needed to customize it to make it mine and to be at least a little bit different. After searching for RC LED kits online I ended up in contact with Dan over at http://mytrickrc.com/. After talking with him a couple of time we put together an LED light package for my Big Rock that I really think is going to make my truck very different. The biggest issue with putting LEDs on a Big Rock body is that no one has light buckets that fit. Fortunately for me while talking to him about the LED's, Dan told me that he has a 3D printer and that he could print me some light buckets if I had a body that he could use to make the models from. So I gave him my unpainted clear body and he was able to make me some really great light buckets that even include a halo light bar under the head lights. As of now I have fully tested the LED setup on the truck, but have not yet installed them my newly painted body. I will be doing that soon and posting more about this installation once I do. For now I figured I would get started by listing what all the LED package is made up of. There is also a picture below of all the parts I have listed here.
LEDs:
Also anyone looking to put LEDs on their Nero, Big Rock, or Fazon with a Diff Brain... I have found that the reverse light work, but not all the time. Dan and I spent over an hour trying to figure out why the reverse light don't turn on some of the time. All we could come up with is that the signal that Arrma installed receiver is sending to tell the truck to go in reverse is slightly different than the signal that most other receivers send. I know that Arrma has put a lot of work into the electronics of this truck to make Diff Brain work and if you have looked at the way it's wired for some reason the motor channel is actually wired through the Diff Brain. I have chosen not use any of these LEDs as turn signals so I do not know if the LED controllers are working with the steering channel correctly or not, but I am guessing that they should work. That is the one channel that does not go through the Diff Brain. All the other features of both my LED controllers are working great. The Dragon controller even piggy backs on channel 3 and allows me to change modes by rotating the diff control switch on the transmitter from all unlocked to all locked and back to all unlocked. However if I move the diff control switch one notch at a time the Dragon controller does nothing and Diff Brain does it's work. I will try and show how this works once I get everything fully installed on the body.
Here are some pictures of the LEDs and the light buckets. Once I get them installed on my newly painted body I will post more pictures and updates of how it goes.
LEDs:
- 4x Super Bright White LEDs (Head Lights)
- 8x 3mm White LEDs (6 are for the front halo's & 2 are reverse lights)
- 3x 5mm Amber LEDs (front marker lights)
- 7x 3mm Red LEDs (Tail/Brake lights)
- 1x 6 inch Attack Series Light Bar
- 1x 2 inch Attack Series Light Bar
- 1x Dragon LED Controller
- 1x UF-7 LED Controller
- 2x Head light and running light buckets
- 2x Halo light inserts (printed from a translucent media)
- 2x Read Tail/Brake/Reverse light buckets
- 1x Tail/Brake light bar
Big Rock Full LED Kit
And it starts... I now have all the LEDs, controllers, and light buckets ready to install. If...
Big Rock Front LED Light Buckets
3D printed light buckets for my Nero Big Rock. Designed and printed by MyTrickRC.com.
Big Rock Rear LED Light Buckets
Big Rock Light Buckets w/ running lights on
Had a little bit of a set back getting the body painted so here is a picture of the light...
Big Rock Light Buckets w/ head lights on
