Erikfireplaces
Also when I adj. The ST my fans will slow down for just a second, not sure if they are the same problem or not.
my 2018 talion has the tactic radio what radio is with ur carsteering trim you say did you adjust the dual rate bc when you do that it will adjust how much it will steer to the point where it won't steer at all try adjusting the dr before you get a new servo
I did, thats when I lost all steering. Made some wierd noises and wouldn't respond to me.steering trim you say did you adjust the dual rate bc when you do that it will adjust how much it will steer to the point where it won't steer at all try adjusting the dr before you get a new servo
Alright will do. ThanksMake sure there's not a rock wedged into the steering arm/servo. I had a similar issue and found a pebble that was causing the issue.
I don't, but^^^^Do u have another servo?
SLT3I did, thats when I lost all steering. Made some wierd noises and wouldn't respond to me.
Im not sure what to put back in it. Same one for$10 or get a better one^^^^Do u have another servo?
