Premium members don't see ads. Click here to upgrade.
Big rock thermal at 125f ?
ThatOneGuy
Illinois
BigRock 4x4
My new big rock is doing the same thing. Very coggy and doesn’t wanna get going and anytime it gets loaded down/stuck it shuts down, off-on and it’s working again. Default settings, stock gearing, does it on both 2s or 3s.
Edit: and it also just hits the brakes and stops right there when it hits lvc. And of course it’s always away from me out in the street.. lol
The bashist
Knoxville Tennessee
BigRock, Granite, , , Talion, , BigRock 4x4
I'm being told the bearings...haven't checked it out yet, but I will give an update when I do.
The bashist
Knoxville Tennessee
Ok so, I just ran a 3300mah venom 35c pack through the big rock. No issues in 31 degree temps. Wth
BRUK
BigRock 4x4
Hi all, new guy here!
Has anyone managed to find out why the big rock gets so hot?
At the end of a 5amp lipo I can only touch the motor for a couple of seconds. This is mainly from driving on tarmac (though at high speed). This is even with an outside temp just above freezing.
Ive replaced all the bearings with rubber sealed ones, tried adjusting the slipper clutch and took a needle file to the motor mount to adjust the gear mesh.
It rolls nicely so I can only think it's the stock setup.
For now I'm going to add a fan to the heatsink.
Any help appreciated!
Notorious J
🦖🏀#1!
The Six baby! We The North! Raptors NBA champs!
Notorious, Outcast 6s
The "touch" method is not your best bet. You need to get a decent infrared thermometer to check temps. A motor can is hot after a good, hard run, but touching it won't tell you if it's too hot. You need to measure the temps, and research what's considered acceptable.
Jeremy in WI
ArrmaForum Fan
Milwaukee
4x4-Mega
I added a fan to the granite 3s for the same reason, clearing 170 deg pretty easily.
BRUK
BigRock 4x4
Forgot to say I have checked with a infrared thermometer and it's up to around 160-170 f. I did try a fan with a much smaller heatsink so I'm going to try the same fan in the stock heatsink.
