- Rhode island
- BigRock 4x4
- Kraton 6s
- Outcast 6s
- Vendetta
- Infraction 4x4
- Thread starter
- #81
Looks good! I love following this build! Keep it up!Started working on my side skirts.im using lexan measured and cut and drilled holes and I'll be nut and bolting it down .since I have the brace in the middle the side skirts will be in top of that brace so to make up for the gaps on the sides I'll cut small peices of lexan and slide them in and bolt them down with the side skirts.after I plan on 3d carbon fiber wrap them in black .was going to spray the bottom side red but I decided to just wrap it all with C.F . I think it will look good . hopefully .still debating on painting my center brace red ..should I? Let me know cause I like the aluminum look but also the red look .adds to my color scheme..I've been also working on the body alot .making a hood scoop .and actually made Two I'll show you guys in a bit .want to know what you guys think.. cool if I could start a poll in my thread but I don't think I can..
This lexan I'm using is 3mm thick should be thick enough at high speeds ..like anything over 50;is high for me
I'll show pics of the pieces I cut to add under to stabilize the side skirts.i could have made just one solid peice and made it my chassis brace and side skirts all at ounce but I didn't want to remove them braces .to many bolts.
Plzzzz don't laugh...I promise I'll make this look goodjust cheer me on and give me that motivation that I need.3 parts from the 2nd big rock cover
I also cut out the lower section of the front nose and will be modifying it to add to the lower part of the front ..making the grill a tad bit longer plus adding 2 more fog lights on the side which will give me 4 fogs and 2 head lights..I already have the lighting but need to extend my harnesses because of the stretched chassis.
Thanks k splitterLooks good! I love following this build! Keep it up!
Sorry meant k spittersThanks k splitter
Haha all good, at basketball games I’ve been announced with my last name being splittersThanks k splitter
Awesome that's what I need to know from a lot so I can make a choice.im going to paint them both and put them on when body is painted then go with the highest choice. appreciate your input means a lot..spread the word in my build because I don't think many see this.kinda lonely in here at timesI personally like the smaller scoop, you did a great job with it so far and it looks like you could buy it that way. The first one, while I love ingenuity, is not my favorite. Not a bad idea though, and not saying it doesn’t look good, just like the other one more!
Well I'll be back in a bit going to throw these onNot expected but I got my spanking bran new silver aluminum shocks .they look so sweet .lm excited to get these on.this install should bring my axle drive shafts back to normal balance angle.im just throwing these on to see how they look but will take them back out to fill with the proper oil..if someone could tell me the correct oil weight for rear and front shocks plz tell me.im clueless to this .would vegetable oil work
I was going to get red aluminum but for some reason I ended going with the silver ..didn't want everything to be red so aluminum should set it off right matching the aluminum center brace I made
I want to make a vid also but it's been so cold out and my wife and my oldest son are chickens .they hate the cold so I'll have to buy some sort of head gear and a go proThose look great! Cant wait to see it running! Also, 50 weight is a good suggestion imo.
It's either that or my phone strapped to my foreheadHaha my family doesn’t like the cold either. Good luck! GoPros are sweet.
