Yeah I have the hex adapter coming and also already have the fan just need to slap it on I’ll check into some gears I guessYep you’re gonna need the 17mm hexes from HR to run those. You will need to step down to a 13T most likely and will likely need a steel spur too. Also prob should grab a motor fan.
No 17mm but have the conversion on the wayThose are 17mm hex. Does the BRCC have 17mm hex? I don’t have one so I don’t know for sure. I think a lot of guys swap out the tires for the Arrma Granite tires which are a little wider.
https://jennysrc.com/collections/ar...es-wheels-tyres-rims-dboots-fortress-ar102666
