Trainwreck
What do I need to change on my 6sv5 Typhon to put Kraton wheels on? Just hubs? Will that still work with stock size wheels
$80 bucks roughly. Any down sides when going back to stock size wheels? Or is it just a little bit wider?Kraton hubs, axle stubs, hexes.
View attachment 135429View attachment 135430View attachment 135431View attachment 135432
I used senton towers, rear talion shocks up front, and rear kraton shocks on the back on my frankenstein.So is that a good thing you think?
Meaning making into a Notorious with Typhon shock towers?
I think so. I don't have huge MT tires. Use the belted Badlands MX28. They are 2.10 wide, 5.04 tall. Kind of in the middle of buggy and full size MT tires.So is that a good thing you think?
I pulled my kraton hubs/axles off to widen it a little there and for wheel clearance but i did the same thing to one rig.I think so. I don't have huge MT tires. Use the belted Badlands MX28. They are 2.10 wide, 5.04 tall. Kind of in the middle of buggy and full size MT tires.
Handles beautifully on the road and rips up some grass rooster tails hard core.
Hey CalebWatch your gearing as well if you change over. The bigger tires will change the load on your motor. I put 4s outcast tires on mine with it widened and ran one with the stock arms and belted 2.8's.
Stock may be ok, you'd have to check temps on it. i know you'll def get better bite so it may be alittle more load.Hey Caleb
So does stock gearing cause problems?
Thanks!
Hmm.Stock may be ok, you'd have to check temps on it. i know you'll def get better bite so it may be alittle more load.
If temps look bad gear down. Put a dual fan setup from power hobby on it and that’ll help too. I ran 18t before I upgraded the motor/escHmm.
I’ll watch that.
If more heat would you gear up or down? My instinct would have me going down a tooth on the pinion but maybe the other way?
Thanks
Now would be a really good time to at least put the hot racing hinge pin braces on if not crcu/m2c while you are still in the building phase.
Did you use the 1/2" offset adapters?I think so. I don't have huge MT tires. Use the belted Badlands MX28. They are 2.10 wide, 5.04 tall. Kind of in the middle of buggy and full size MT tires.
Kraton hubs, hexes and axles.Did you use the 1/2" offset adapters?
