Biggest 3S Battery
Thread starter #1
andrewh
Likes
1
Kraton, 4x4-Mega
I'm difficulty trying to work out what pair of 3S batteries to get for a 2018 Kraton. I'm trying to get maximum mAh and C rating which will fit into the battery tray (without modifications), which won't break the bank and are available in the UK. Any recommendations would be much appreciated.
olds97_lss
ArrmaForum Fan
Likes
649
TBH, your better off finding a lighter battery that fits as larger batteries add weight. Since it's a Kraton, I'm assuming your going to be airing it out some. Less weight is less abuse on the suspension and chassis overall as it slaps the ground.
I used to run 9000mah 2S SMC packs in my erevo and savage flux. They weight quite a bit more than the 7200/7400's I was using in my smaller trucks. I stopped buying the big packs and now only get the 7400's. Seemed to have made a significant difference in suspension problems overall. Also, less weight means cooler temps and in the end, I only lost a couple minutes run time while gaining higher C packs that charged faster due to being smaller.
Thread starter #3
andrewh
Likes
1
Kraton, 4x4-Mega
That makes a lot of sense - perhaps I should just get 2 sets of smaller batteries to extend the run time.
Similar threads
