Thermal shut down before you hit the low voltage cut off. You need to add fans to the motor. I’m running 6s 5200mh. I’m getting about 20 minutes of run time racing against others. Before the fan 195 degrees at the end of a run. With fans 125 degrees.
Lvc is factory set at 3.7 volts. No way should you be running it to 3.2 volts in my opinion.20 minutes and the vlc hits? At what voltage your vlc kick in?
