Vendetta Biggest pinion on stock vendetta
I believe its the same as the other motor mounts so 26t with standard spur will be the largest. Not 100%
Regardless of clearance you may need to consider changing out the esc, the spektrum esc is dog sh1t and will cr@p out with the slightest over loading problems. Don't go too far unless you want to put a decent esc in there.
I'm putting a castle MMX8 and 1515 2200KV motor in mine and the 30t pinion I bought from saga seems to be the biggest I would be able to fit. It might be because of the size of the motor.
