Misfits4200
What size motor can fit in the just bash it chassis i was looking at the 800 kv hobbywing but not sure if it would fit or if a pps. Motor mount would fit the 800kv
What motor mount are you running? A PPS with the 30mm plate should fit it.What size motor can fit in the just bash it chassis i was looking at the 800 kv hobbywing but not sure if it would fit or if a pps. Motor mount would fit the 800kv
Ya the pps 30 mm will the 800kv hook up just like the 1100kv?What motor mount are you running? A PPS with the 30mm plate should fit it.
They are the same diameter can, 56mm.Ya the pps 30 mm will the 800kv hook up just like the 1100kv?
What about the length i just don't wanna go with a 800kv and then it not fitThey are the same diameter can, 56mm.
Pretty sure it will fit. I have a 4092 in my K6EXB and there is at least 50mm more space after the can. Almost 60mm.What about the length i just don't wanna go with a 800kv and then it not fit
I plan on useing it for speedruns and just all around driving what size pinion gear should be use with that ?2028 cans fit, but they are wasted in an 1/8 scale rig not being used for speedrunning.
So useing a 800kv motor what size pinion would u need to run it correctly?They are the same diameter can, 56mm.
You'll have to gear it to the moon unless you run 8s. possibly snag a 46t spur and a tall pinion.I plan on useing it for speedruns and just all around driving what size pinion gear should be use with that ?
Speedrunning and general driving are completely different. Like buying a Ferrari to go offroading with 5 other people in the car. The setups for a vehicle to do one or the other are so vastly different it isn't even worth considering doing with the same car. Power system, esc settings, transmitter settings, wheels/tires, shock settings, suspension settings, chassis settings, the list goes on and on of things that have to be completely changed to reasonably run for speedrunning or bashing.I plan on useing it for speedruns and just all around driving what size pinion gear should be use with that ?
I have a full deaked out basher so speedruning is what this one is going to be built for when i saod general rideing around i ment on flat surfaces with no bashing i put thought into it and im trying to completely deak out a kraton 6s for nothing but drag raceing just wanna make sure i take the right steps towards building one fast m.fSpeedrunning and general driving are completely different. Like buying a Ferrari to go offroading with 5 other people in the car. The setups for a vehicle to do one or the other are so vastly different it isn't even worth considering doing with the same car. Power system, esc settings, transmitter settings, wheels/tires, shock settings, suspension settings, chassis settings, the list goes on and on of things that have to be completely changed to reasonably run for speedrunning or bashing.
