mickRR
- Kraton 8S
I have the castle mmx8s with paired sensored 800kv motor 20mil in center diff and 500k in front and 1mil in rear. 42t pinion. And I have gone thru 3 rear diffs so far. Is anyone else having this problem or does anyone have suggestions for me to stop going thru rear diffs?
On the first diff i sheared the cap screws right off and then screwed up the spider gears. On the other 2nd I'm ruined spider gears and on 1 the case was weak and had a crack and the other the case the cap screws were fine but spider gears were trashed I have since moved my punch level to 30% it seems to be working now. And the first diff. that went out it started with a clicking. So if you haven't already check it and you may be able to save yourself from buying new spider gearsI’m running pretty much exactly the same setup, except 43T and 500k F/R.
What part of the diff are you breaking?
Mine just recently started clicking but haven’t opened it up to inspect yet..
