Blew up 3 tires yesterday. Do you guys usualy buy pre-mounted wheels and tires or just the foam and rubber and glue it yourself? Is it hard or annoying to mount them yourself?
^ you can change diff oils.What are you doing when it blows?
Diff out can put a lot of extra spin on a tire and blow it off....so manage your diff weights (change). Check the tires before as new and after each run and glue as needed. I personally just add glue over the existing for new tires now.
If you diff out even with a good glued tire, you can spin it so fast that you just exceed the specs of that tire, and it comes off and even an older tire if not checked often.
Yes, that's what they do when you do that. Any non belted tire will do that.I don't understand what diff'ing out means. In my case the truck flipped onto its back and I held down the trigger too and they blew up
Were you trying to do a standing backflip? did you purposely hold the throttle while the rig was upside down? You still never answered any of my questions lol. Was it the front tire? it probably was. As @Crunchy Gears alluded to, you probably shouldn't be gunning the throttle while the rig is upside down.I don't understand what diff'ing out means. In my case the truck flipped onto its back and I held down the trigger too and they blew up, no amount of glue would have saved them since they didnt come off the whees, just blew up the rubber
