Kraton Blue bird servo BLS-H50B F
shouldn't need anything, some people like to replace the servo horn with aluminum, but its not needed. however, you may need to add a glitch buster if you find you are getting brownouts. I'm not sure if the Blue Birds have this issue like higher powered savox servos do though.
some might suggest running an external bec. that servo is a monster. im going to be getting one as well and will be running an external bec to provide the amperage it will consume.
Won’t hurt to run it first and if experiencing brown out add the buster. If not save the $ for other hop ups.
