Blue loctite..
abracing
Limitless, Kraton 6s, Talion
..put big drop of biue loctite on pinion gear grub screw. On limitless, running 6s, not holding.. anyone else have same issue ??.. afraid to use red..any suggestions ??
abracing
Use a little red just heat it up to remove.
Another option is disassembling a old bearing and using a single ball under the grub
Tried little bearing ball under grub screw, then a big drop of blue loctite..ran limitless 100+mph , until 6s was done, it held..thank for the tip..herd of doing this before at kart track..but forgot..lol..
Hammer Down
Are you silly? Of course I’m gonna SEND IT!
The coldest place on earth!! (Aka) Minnesota
Infraction, Kraton 8S, Kraton 6s, Outcast 6s
Did you let it cure for 24hrs before giving it the hamm?!
abracing
Shure did plus some,more like 3 days before had time to mess with it again..then there is the Michigan weather..rain,rain..Guess know about weather being..in minnosota..lol..
Create account
Log in
