BLX 100 ESC punch setting affects Throttle switch?
DanG
New Member
Hello! Still a newb here. I have a new Granite 3S with the BLX 100 ESC paired with a SLT3 Transmitter.
I wanted to test different punch settings and I'm pretty sure that I tuned the ESC correctly, raising the punch setting from the default Level 3 to Level 4. However, after changing the setting, the throttle switch/limit on the transmitter (50/75/100 TH/LIM) seems to have lost its effect having 100% throttle regardless of setting.
Is that normal behavior?
I searched and searched but did not find anything on it...
Well what do you know! I could have sworn I had tried but I did it again and it seems to have worked!! Maybe I didn't have the switch at 100% when I calibrated...
Thanks for the quick help!!
