BLX 100 ESC switch replacement
Mortislock
New Member
I have a Typhoon 3s with the stock BLX100 ESC
I have found a lot online regarding this switch as it seems to be a common fail point
I know that Arrma does not do a spare for the switch alone and I found a replacement online and would like your expert advice if this will be ok to use.
Replacement switch
I have electric solder connectors to make a water-tight connection if this switch will work
Thanks in advance :)
