Jluther@becoinc
- Senton 6s
- Talion
How did it work out for you? Any more power? Did you have to set the punch lower ?Yep.
The biggest issue is the BLX185 does not have very strong brakes compared to other ESCs. As far as power, I ran it on 6S so yeah more power.How did it work out for you? Any more power? Did you have to set the punch lower ?
Thanks for the info I just didn’t want to ruin a motor or escI ran the BLX185 ESC in my Granite for a bit. 3s and 4s. No issue with the brakes, remember the 4x4 trucks weight a lot less than the 6s trucks. Motor was the BLX185 2050kv.
I also ran the BLX185 ESC with other motors, like a 3000kv f540, a 3660 3800kv, and a 3650 3300kv. With those motors, the brakes were very strong.
Yes same motor. 2400kv 3660.Stock motor?!?!
This was in a Typhon 3S using a 3660 2400kv motorI ran the BLX185 ESC in my Granite for a bit. 3s and 4s. No issue with the brakes, remember the 4x4 trucks weight a lot less than the 6s trucks. Motor was the BLX185 2050kv.
