JohnnyBLX185
- Talion
I'm trying to figure out if my BLX 185 is dead or not. I turn it on and the green light flashes--I think that is normal. But then things get weird. The throttle only sporadically works, sometime the motor runs, sometimes I get three flashing green lights and sometime I get a fast green flicker (and the motor chatter you get when you are programming the ESC). Then after a few minutes of futzing around I get a solid green light and no throttle. I've tried the factory reset and manual programming steps--ESC does nothing. I was able to see my ESC settings and reset using a programming card, but that did not help.
The battery I'm using has plenty of power and the radio is working fine (still have the stock STX2). The truck is a Talion v4.
Any hope, or should I start shopping for a new ESC?
Best, JohnnyBLX185
Best, JohnnyBLX185
