Stapleton219
- Nero
My Big Rock ESC does not react the way the manual states it should when changing the programming for things like brakes, punch settings, etc. I can get it to make changes but the manual says it should make certain light flash sequences and colors. Mine does the correct flashing sequences but not the correct colors. Just wondering if anyone else was experiencing this same issue?
Also, I have 6 batteries, all new Duratrax 5400 mah, 50c packs. When I run the truck till low voltage cutoff, my packs are discharged at different rates. Not just individual cells, but one pack might be 9 volts while the other is 10.2 volts. The ESC doesn't care about each cell of each pack being 3.2 volts which is the cutoff but it looks for 19.2 volts and doesn't matter how the individual packs are discharging. With the packs being wired in series, you would think they would discharge evenly..? Support claims that the steering servo is powered by the ESC as a whole and does not feed from one particular battery wire, thus would not cause uneven discharge. They actually replaced 2 of my batteries thinking they could be defective especially since they puffed slightly after discharging below 3 volts on a couple cells, but the problem persists even with all batteries being new and less than 10 charge cycles each.
Anyone smarter than me wanna educate me on why this is happening?
