Blx 200 ????
NWI_RC
BigRock,
I own a arrma Nero Big Rock, and my esc has shut down and throws a 4 green flash code. Manual/internet searches leave me in the dark. Called tech support and the tech wasn't aware either? I would send it in but unfortunately I'm second owner with no receipt..
IF anyone has experience with this or knows what the code is please help. Thanks
Maxxwrecker07
IA
Senton
That's a protection fault, usually overheat. Check your truck for binding in the transmission and steering (BEC will set it off too.) I figured it out by looking up the max8 ESC by hobbywing. Good luck!
NWI_RC
BigRock,
Thank you so much!! Just ran it now without issues after sitting for 1 hour. I was going through sum thick brush and had tall grass wrapped around rear driveshaft (was unaware), so sounds like binding Thanks again, much appreciated.
