Blx 200 ????
NWI_RC
  1. BigRock
I own a arrma Nero Big Rock, and my esc has shut down and throws a 4 green flash code. Manual/internet searches leave me in the dark. Called tech support and the tech wasn't aware either? I would send it in but unfortunately I'm second owner with no receipt..
IF anyone has experience with this or knows what the code is please help. Thanks
That's a protection fault, usually overheat. Check your truck for binding in the transmission and steering (BEC will set it off too.) I figured it out by looking up the max8 ESC by hobbywing. Good luck!
Thank you so much!! Just ran it now without issues after sitting for 1 hour. I was going through sum thick brush and had tall grass wrapped around rear driveshaft (was unaware), so sounds like binding Thanks again, much appreciated.
