Blx 3s motor on 4s castle x esc
Casper391
  2. Kraton 8S
  3. Typhon 3s
I have a castle extreme ESC running on a Blx 3S motor 26 tooth pinion, heat sink and double fan on motor. Running on a 4s lipo. Motor seams fine heat wise have not seen it get above 150 ish yet. Esc is shutting down for a few sec then picks back up. Dosen't seam to have full power and no breaks. Please help.
Which castle esc are you running? Mamba max pro, mamba x, or a mamba monster x?
Running the castle mamba extreme 1:10 scale with sensored capable. I finally got working right after calibration.I finally got a few high speed runs in highest motor temp 207 on the data log. Any suggestions? How to make it not cogg so much on starts. Punch set to 25 % motor power set to 100%.
Yes I finally got working right after calibration. After I finally got a few high speed runs in motor temp 207 on the data log. Go
What is the sensorsless motor timming option? it is set to normal[10]
Mamba x?? If so, your motor isn’t fit for your application.
What motor would you suggest? 2.8 badlands.
BLX120 & 2400kv from 4S rigs cheap on JRC
I’m pretty sure he’s telling me that he has a mamba x, which is way way more powerful than a blx 120. Id pick up a hobbystar 3670 can if it’ll fit.
How is your data logs picking up motor temp? It would need to be running a sensored motor for that. You must be reading ESC temps.
Picked up a castle1512 1800kv. Running with a 26 pinion and (57thooth supr gear) still on 2.8 badlands.I believe 57 is stock. Have not run it yet. I will update with esc and motor temps. Thank for the help guys.also when I was trying the stock blx on 3s on 4s I had a temp gun.
It was running the castle motor at time the the each came with.motor is a 1406 4600kv geared down to a 15 tooth pinion still getting to hot. So I picked up a new motor today. Castle 1512 1800kv.
We will see how it goes tomarrow. Granite 20tooth pinion 2.8 badlands with 10mm hex adapters with fan on heat sink and a bearing kit otherwise stock. Time to Bash.....
Typhon blx 4s
25 tooth pinion 57 tooth spur gear.183 on motor temp running 4s 126 on esc.
Granite blx 3s
145 motor temp 115 on esc 20tooth pinion 56 tooth spur gear.
Looking good guys. Thanks for the help.
Might have to have new stickers made for the cars going to call them ankle killer 1 and 2 lol.
