Granite BLX axle u-joints keep popping
Elijah890
Does anyone have a fix for the u-joints popping out of the Axles every 5minutes? Getting tired of buying stock ones and I like my slipper set up the way it is. Is the any upgraded ones people are using and aren’t 6 months away?
It all comes to slipper setting. The have steel axles but if slipper is too tight it will eat the diffs next
It's a common problem. Once the u-joint pops they will continue to pop. You should get new driveshafts. Loosen the slipper before using the new driveshafts. A CVD driveshaft upgrade will eliminate the problem completely. I use stock driveshafts and have not had a problem, I keep my slipper backed off and I think GPM aluminum knuckle arms may make a difference.
