bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
EDIT: You also need (4) M2.5x12 cap head screws for the diff case. You can reuse the screws for the stock housing.
I went to Tower Hobbies and ordered the parts needed to build 2 new BLX differentials. They are all in stock. I ordered (2) AR310872 (Diff case), (2) AR310873 (HD Input Gear and (1) AR310875.Everything else should transfer over from my extisting diffs. The BLX gears are much thicker and the input shaft is metal. Total cost was $36.10 but I opted for the two day shipping. Without shipping it was $31.11.
These diffs should be bullet proof. The final drive ratio is almost the same as the stock diffs (2.864 vs. 2.882). And less than $16 a diff isn't bad for something that should last forever. The rest of my initial order for my Granite should be here today (what I just ordered will be for the Senton). I will post up some pics when I get them.
Has anyone ordered/received any of the new motor mout/slipper parts?
