ArrmAh
Any suggestions/tips on how to remove the 3 BLX motor screws so that I can to the bearings? I find them so soft and starting to strip..if not stripped already.
Torch them then try. Stripped ones get a slot cut to fit a flat head screw driver then heat and come out like butter.
Yep cheap as all get out lol harbor freight. Thin cutting blade does the trick. Steady hands as well. Cut until the flat blade fits nicely.Wow as newbie this is all good info to soak in. So you use a Dremel tool to make the cut...??? I have one but its a cheaper cordless one...well I have the bigger powered one in the garage but it's meaty in size for an RC
