Typhon BLX100 ESC Relocation on Typhon 3S
I did this on my Typhon as well but I mounted mine the other way around.
-edit- I lied mine is the same way.
Can you still remove the motor? Or do you have to remove the ESC every time you pull out the motor?
Idk I haven't tried but I am assuming that it needs to be removed first
I always route my battery wires in the Velcro straps. Both side actually. I do like option 3 and am considering doing this to both my 4S rigs ASAP. ??????
I personally like the esc down in the chassis.. I've been running mine like that since I bought it.. and yes you must remove the esc to remove the power module.. but no big deal, couple screws and flop it over the side of the chassis...
Your battery lead is so much longer than mine. It's seriously only like 3 inches long.
Yeah that's the way all the new esc's are coming through.. caps and longer wires.. I personally hate when caps are added to the battery wires, it's just something else to go bad in my opinion... I'd much rather have the shorter wires..
Is this a typhon 3s? If so where did you get the chassis brace? Did you have to get different diff covers to get it to connect?
It was a Typhon 3s, it's the stock brace for the Kraton 4s I bought it off ebay.
I'll get you a list of stuff that you will need.
Tower to tower brace https://jennysrc.com/collections/ar...ed-center-brace-240mm-bar-ara320532-ara102690
Center brace pin https://www.arrma-rc.com/part/ARA320529
M2.5 lock nuts https://www.arrma-rc.com/part/AR715008
M3x10mm Cap Head Screws https://www.arrma-rc.com/part/AR723310
Brace mounts https://www.amainhobbies.com/arrma-4s-blx-center-brace-mount-set-ara320528/p967955
Body post set https://www.arrma-rc.com/part/AR320452
Body Mount set https://www.arrma-rc.com/part/AR320453
If you search Jenny's and the kit breakers you usually can get all the stuff for less than buying everything separately plus you get spares of other stuff.
Thank you so much!
Slick is on it today!
