i was reading the Hobbywing info and came across the part where they mention that when running 6s you should measure the temp of the capacitors on your esc and if hot(170f) you should install a Cappack as Hobbywing calls it right at the esc's + &- battery wiring.My caps on my Max 8 get up to 165f, so i think i may need them?Any thoughts on this?I no the included battery wiring doesn't help because of length.
