DoNoHarm
- Senton 6s
I got it stuck in programming mode once but after a few power ups and downs I finally got it to fire up. Been good since. You know, if you really want to, you could buy a parallel adapter and do what the old school hobbywing 150a users did. Basically a lot of times the esc would shut down mid run, and you would power it up and it’d be fine forever but next time you turn off after the run and then turn it back on the next time you go out, it’d burn up. So to combat it people decided to never let the esc turn off (basically if you ran 6s, you’d plug a 6s pack into the parallel adapter before you unplugged your battery that you just finished with, and then when it was time to run you’d plug in the other battery and take out the one that was plugged in while the truck was sitting.
