slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Really? My Arrma body clips bend really easy, I replaced them with Amazon cheapos and haven't bent one of them yet.Yeah, I do the same. Just bend them up. I use 2 large dikes. Give them a 45 degree bend. Easy to finger grab them. But Arrmas are the strongest. Spring steel. Many other brands are crap metal clips. Sure the may be easier t work with. But also fail easier. Been there.
It would also help if you open up the post holes with a drill bit some more. The clips will slide in better. Even some Chapstick on the clips and inside the post holes makes it smoother to insert and remove.
Generally there are 1/8 clips and 1/10 clips. The 4x4's use Arrma1/10 clips If I am correct.
